Wheel speed sensors
bowez
Does this sensor look bad? Was bent even worse before I straightened it.
ABS light on and complaining about several speed sensors, may have a bad unit too by code 63.
Where are replacement sensors available? Even if need to do some wiring.
Front sensors are no longer available. Junk yards would be your only source. Rear sensors can be found on Ebay. I'm sure its limited availability.
The sensors can be tested using a multimeter. There is a chart floating around somewhere on the Internet listing the values.
I was able to use a front sensor from a mark viii on my 91. The mark had a different connector than my 91, so I had the wire in both the female and male connector of the mark sensor to make it work.
I can testify to that. Looked high and low for the fronts and no where to be had. I got the rears of eBay NOS. I ran an Ohms test and it came back 1143 which is within spec. (800-1400 is spec) Not sure if these are active or passive sensors as far as trying to get some AC readings when spinning the hubs.
