My white 89 SC daily driver got some service, and repairs, this week. Basic lube, oil, and filter. Inspect everything underneath, including brakes. Replaced main accessory belt, (gates), and inspected everything that spins. Replaced power steering cooler hoses. Required cutting off crimps, and slightly flaring ends. Replaced PS fluid,(type-F), and bled system. With the wheels off the ground, I crank the engine, while holding the throttle wide open, so it doesn't start. Then I turn the steering wheel fully to the left, then right, and back to center. Adjust fluid level. Nice and quiet, this way.
I finally replaced my leaky radiator, with the Chinese Liland aluminum unit. With some bracket re-drilling, and tweaking, I got it in. Flushed system. Works OK, but doesn't seem to cool much better, than my 36 year old one. Doesn't leak, so far. Oh, and I replaced the old tired used Motorcraft battery, with a Everstart Maxx, group 65. We will see how it holds up. I usually get 10+ years from "good quality" batteries. It does crank over faster. I have put over 22,000 miles on it, since bringing it back from the dead, not that long ago.
